o2 sensor
You can weld bungs in yourself, the tricky part will be drilling through double wall Ss without the bit grabbing. If you can do use a mill or CNC you will be happier
look for O2 sensor (digital) airfuelspark.com simple to use and all in one package
http://www.innovatemotorsports.com/products.php
pretty happy with the lm-2 if you get the inductive clamp you can map to rpm for your application ( i think)
I had this idea for years,,if its a big block and if its a hp style manifold you could remove the intake and drill and tao the center where the exhaust port would between the 2 center intake ports..it will only regesture the 2 center cylinders but its still exhaust gasses that you need to read..
Love that idea Fixx! That way you can run without the worry of water killing the sensor. Have you ever tried that? Is there enough gasses flowing through there to register good readings, I wonder.
