2 questions one on the pooper one on the flapper. >
Old 06-12-2002 | 05:26 PM
Raypanic's Avatar
Question 2 questions one on the pooper one on the flapper.
I was working on the boat today trying to get the head working, The pump does not pull in water from the lake. The valve that is on there is missing the handle. Problem is I seems it is a valve like a faucet I can just barely reach it with a wrench but the spindle keeps on turning and it doesn't stop like others. From the picture can any of you tell me how this valve works I tried turning it 90 degrees at a time and cannot seem to get any suction or tell if it is open.
Second, My CMI air operated tips only stay closed about 1 minute after engaging the pump then they slowly open, Is this normal or should they stay engaged longer? One of the pistons is slow and I think posibly it is leaking. Any ideas?
Attached Thumbnails 2 questions one on the pooper one on the flapper.-sillcock.jpg
Ray
Raypanic is offline
Old 06-12-2002 | 10:02 PM
Audiofn's Avatar
Charter Member #232
Check for leakes in your exhaust system
As far as the valve I would pull the boat and shine a flashlight in there and look at the valve. It should be a ball valve. to open it turn it 90 degrees as you have done but you could be a little off each time and you will never get her correct. Then put a handle back on it. There could be another valve that has to be opened up on the toilet or some were else in the boat. I know on my fathers boat there were three valves to open up to make it work.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-12-2002 | 10:41 PM
Tinkerer's Avatar
The valve will have flats on the shaft. When the flats are inline with the valve outlet it is open- across the valve is closed.
If your air operated cylinders are opening back up then there is an air leak. Check all the hose connections and the hose itself for places it may have rubbed a hole in it. Lubricate the cylinders with dish soap. This will get them operating smothly.
Tinkerer is offline
Old 06-12-2002 | 10:56 PM
Ted G's Avatar
You may need to prime the water line into the head. Mine tends to air lock every time I put it on the lift. If you need to prime, just pull the hose at the head and pour water in there. If it keeps going down you may have to close the valve, fill it and then open the valve after putting the hose back on. You may also have a leaking valve in the head that is not allowing it to pull properly.
www.cbpba.com
Ted G is offline
Old 06-12-2002 | 11:10 PM
Scott's Avatar
Charter Member #30
Ray,
Sitting here LMAO been there done that After the first year running I found my ball valve handle in the bottom of the bilge. I put it back on with loc-tite end of problem with the valve. If you have a manual head give it up and buy a electric Mary and I got arms like popeye from pumping that damn thing the seals don't last and you will have nothing but major headaches with it. I did everything I could think of to fix it and finally bought a electric at West Marine a couple of hours worth of re-rigging and your good to go.
I can show you my changes on Friday
I have Steps & Bubbles!
Scott is offline
Old 06-13-2002 | 10:37 AM
formula31's Avatar
Ditto on the electric head. 2nd best money I ever spent on the boat. As far as the flappers go, I built a mount below the pivot and attached a spring that works like an over center cam and provides some holding power in either open or closed position. That way they will stay in whatever position the air cylinders put them in no mater if the air pressure goes away. If you want I can take a picture of it.
Tom
formula31 is offline
formula18
06-04-2007 02:51 PM
mtgbiker
01-14-2006 05:42 PM
klaw
2
04-19-2004 07:09 PM
kook
07-13-2002 12:44 AM
C_Spray
04-08-2002 11:09 AM
