first time in saltwater for extended stay >
Old 10-23-2011 | 08:10 AM
Default first time in saltwater for extended stay
Going on a week long trip to Tampa area. Do I need to flush with fresh water every night or just when I put her on the trailer at the end of the trip? Anything else I should know?
tnc110 is offline
Old 10-23-2011 | 08:33 AM
I would think that a 1 week stay wouldn't require a daily flush and that a thorough flush at the end of the week on the trailer would be fine.
If you intend to do this in the future on a regular basis, I would suggest installing a Neutra-Flush system.
I'm sure others with more knowledge about this subject will give you more advice.
Hematite is offline
Old 10-23-2011 | 08:43 AM
Is your engine raw water cooled? If so, any aluminum components like intakes? If you do I would give it a quick flush every day.
JTeam is offline
Do you have fresh water fittings? We make a couple trips in salt a year, flush every night, wash the entire boat down in the morning and evening. I also use CRC to spray the engines and wiring down. I will also run it in fresh water when I get back to get all the salt out.
redbud35 is offline
Old 10-23-2011 | 09:07 AM
raw water cooled with no aluminum...100% stock 454 mag. A "T" and two ball valves in the waterline that goes from the transom to the impellar would allow me to flush in the water.
tnc110 is offline
Old 10-23-2011 | 09:09 AM
tnc110 is offline
Old 10-23-2011 | 05:31 PM
scottw's Avatar
What year 454 Mag. Mine is a 1990 and came from the Mercury factory with a aluminum intake. Better double check that. Either way if you can flush daily I would.
scottw is offline
Old 10-23-2011 | 06:00 PM
+1
If I were you I would flush after every single use. It's just not worth it to chance it. Salt is some nasty sh!t!!! Oh and CRC is a must too!
jasonmd2 is offline
Old 10-23-2011 | 06:04 PM
Boater8987's Avatar
Airking
Here use this. Low cost, simple to use and removes salt from motors and boat exterior.
http://www.saltawayproducts.com/
Boater8987 is offline
Old 10-23-2011 | 06:55 PM
Expensive Date's Avatar
Its salt not acid,flush if you can run the boat in fresh water for an hour when you get home clean it good and no one will never know.
As for aluminum I rebuilt a Jet-Ski engine after 10 years of only salt use.They have almost all aluminum engines and manifolds,there was no corrosion at all. So in my opinion aluminum holds up better than cast iron.
Expensive Date is offline
