Engine Cover With Rear Seat Back Combo >
Old 10-23-2011 | 09:45 PM
Default Engine Cover With Rear Seat Back Combo
I am building a new engine cover and thought about making the back of the rear bench seat part of the cover like alot of newer boats I think it might be eaiser to work on the engine belts pump alt ect. Is this worth doing?
TwoKs is offline
Old 10-24-2011 | 07:18 AM
Make sure the structural integrity isn't given up when doing this -- the firewall offers most boats alot of strength...
delsol is offline
Old 10-24-2011 | 02:30 PM
Sonics engine Cover and rear seat including seat bottom are all in one......
However, the above statement makes alot of sense too.
45Tripps is offline
Old 10-24-2011 | 05:54 PM
thanks for input. Cutting out firewall would probably be a bad thing.My cobra doesn't have one. It does have a strong built bulkhead from the floor down and the rear bench sits on top of it. I was thinking of using 3/4 deckolite ,making and glassing a lower bench to the floor and into the sides. any thoughts or ideas
TwoKs is offline
Old 10-25-2011 | 07:23 AM
fastedy's Avatar
34' SUPERBOAT, easy access
Attached Thumbnails Engine Cover With Rear Seat Back Combo-enginecompart.jpg
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 10-25-2011 | 07:37 AM
My 28 ZX has it integrated. The bulkhead is solid below and tied into the main center stringer and the sides of the boat.
VetteLT193 is offline
Old 10-25-2011 | 09:27 AM
Smitty's Avatar
Also make sure that if you do it , that your hatch lift is up to the task of the increased weight.
Smitty is offline
Old 10-25-2011 | 06:48 PM
should I build a flat fire wall which will be part of the engine cover and than bolt rear seat frame to it or do i build the rear seat frame as the firewall? I am building a plug and than a mold from that and than the engine cover and rear seat back from the mold out of fiber glass
TwoKs is offline
