454 merc need cam
Old 10-25-2011 | 05:13 PM
Default 454 merc need cam
so i want a little more umfff from my 7.4 merc, i was thinking the cheapest way to go is a cam but not sure what kind to get. i was looking at this one http://www.jegs.com/i/Comp+Cams/249/11-236-4/10002/-1 at Jegs but not sure if its to much for a stock set-up.
grease is offline
Old 10-25-2011 | 06:39 PM
dykstra's Avatar
Go with a full roller cam. It IS more expensive but you will be better off in the long run.
dykstra is offline
Old 10-25-2011 | 10:33 PM
Just a cam change is not going to do that much. Maybe 30hp which = 2mph.
Also, to go with any cam bigger than a stock 454mag cam, you are going to need betetr exhaust to prevent reversion.
Is it carbed or MPI????
Griff is offline
