Bank to Bank Temperature Differential >
Old 10-27-2011 | 09:08 AM
Default Bank to Bank Temperature Differential
I just purchased a good temp gun and finding all sorts of uses for it. I discovered that my right bank runs 15 to 20 degrees cooler than the left with and engine temp of 150 and oil at 200. I just rebuilt the motor and everything has been flushed and cleaned thoroughly. I am running a crossover with a bypass and thermostat that's been drilled. Has anyone else experienced this? How is the temp balance when using a circulation pump? Has anyone tried a high performance electric circulation pump?
ThisIsLivin is offline
Old 10-27-2011 | 01:45 PM
One side is always hotter on every engine I have owned and they all had circ pumps. Seems to be warm enough so should be good.
Pismo10 is offline
Old 10-28-2011 | 08:38 AM
If by bank, you mean cylinder bank, mine run within a few dgrees of each other. However, my exhaust manifolds run 15-20 degrees different from side to side. I did a search when i discovered that, and it seems to be pretty common for manifolds to differ.
apollard is offline
Old 10-28-2011 | 11:03 AM
15-20* is nothing to be concerned about.
Griff is offline
Old 10-28-2011 | 08:26 PM
water with take the path of least resistence every time, so the bank with the best water flow will be the most cool
firehawkcat is offline
Old 10-31-2011 | 02:11 PM
Has anyone tried a high performance electric circulation pump or restrictors on the cold side? I am measuring the temperature differential on the front of the cylinder head to get the most accurate read. I pushing this motor pretty hard and don't want to ruin my fresh rebuild by detonation.
