Go Back  Offshoreonly.com > Owners Forum > Powerquest
the weight of my 257 pq >
Old 10-28-2011 | 03:36 PM
Default the weight of my 257 pq
Hey all, can't find my owners manual-whats the weight on my boat...looking at a naylor 4500lb boat lift, will it work. Thx
paintman is offline
Old 10-28-2011 | 04:41 PM
Your boat weighs 4250 lbs. That lift may not be big enough for your boat. Once you add fuel and gear, you'll be over the lift limits.
chicagoremi is offline
Old 10-28-2011 | 07:01 PM
Unhappy
Just my freakin luck...great deal 3k used 1 summer.....
paintman is offline
Old 10-28-2011 | 07:53 PM
That's to bad. I sold my 5000 lb lift in the begining of this season. I wasn't comfortable with it anymore.
Old 10-29-2011 | 09:14 AM
How do you mean-"not comfortable anymore" not heavy enough?
paintman is offline
Old 10-29-2011 | 09:38 AM
Get at least a 6k lb lift,,by the time you add fuel,gear and all the other bs that goes along with boating the 257/260 legend gets pretty heavy.
boatnt is offline
Old 10-31-2011 | 08:33 AM
This summer I weighed my 257 BR and trailer, then the trailer alone - the boat weighed 4950 lbs with half a tank of fuel and the usual boating crap. No idea if the BR weighs more / less than the cuddy.
apollard is offline
Old 10-31-2011 | 09:05 PM
That weight sounds about right. The BR weighs about 75 lbs less than the cuddy. I snapped a (newer) cable on my 5000 lbs lift. I agree about the 6000 lb lift.
Old 10-31-2011 | 09:22 PM
Josh LaFountain's Avatar
At my marina the smallest ones thay will let you use are the 6500lb lifts. but thay are all Hydro Lift. Thay use air to float the lift. and all thoes have smaller BRs on them 24 and under. all the upper 20s and 30s have the larger 10k lifts. maybe just a safety percaution IDK?
Josh LaFountain is offline
