Kodiak Brake Install
Old 10-28-2011 | 09:10 PM
Prater's Avatar
Default Kodiak Brake Install
I asked in my other thread, but it is old and just resurected...
The install book shows that the left calipers should be mounted at 3 o'cklock and the right mounted at 9 o'clock. I have always been under the impression that disk brakes perform better in front of the axle centerline instead of behind the centerline. I just wanted to make sure that I will be mounting them correctly behind the centerline of the axle towards the rear of the trailer according to the manufacturer...please correct me if I am wrong before I get all six brakes mounted. Figured it would get answered quicker here than an email to Kodiak.
Prater is offline
Old 10-28-2011 | 10:16 PM
I did the same install this summer and I too installed at 3:00 on the left and 9:00 on the right. The brakes perform awesome. I also did quite a bit of research before selecting the Kodiak system and all the videos and installation documents show the caliper installed at these positions.
Good luck with your install, you will be happy with the results!!
Also may want to think about upgrading to a brake-rite electric/hydraulic system. So much better then a surge system!
502ss is offline
Old 10-28-2011 | 10:19 PM
Prater's Avatar
I have a Dexter EOH system going on also...
Thanks for the response.
Prater is offline
Old 10-30-2011 | 07:24 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My Kodiaks are mounted to the rear. It stops when I hit the brakes
US1 Fountain is offline
Old 11-02-2011 | 08:19 AM
Dexter is the only way to go.
dewayne6243 is offline
Old 11-02-2011 | 09:09 AM
I have been wanting to do the EOH conversion on our trailer. I am familar with the Brakelite but not the Dexter. Where can I find out more information about this system and why do you like it more than the Brakelite?
And just to keep from hijacking this thread too much, from an engineering perspective, it does not make any difference whether the caliper is mounted in front of, behind, on top, bottom or any other location in relation to the axle, at least in terms of braking performance. It matters greatly in terms of the orientation of the bleed nipple on the caliper and being able to get all the air out.
Dan
BajaDan is offline
Old 11-02-2011 | 09:22 AM
If the factory recommends 3 and 9 oclock then do it. Theres a reason they do, they are the experts.
Wannabe
wannabe is offline
Old 11-02-2011 | 07:36 PM
there are bleeders on both ends of the Kodiak calipers if I remember correctly
search my thread on my conversion and other trailer upgrades
you want the caliper trailing
Actuator?
BrakeRite HD !!!
Rippem is offline
Old 11-04-2011 | 07:32 PM
Prater's Avatar
Yes there are bleeders on both ends of the caliper. Here is one installed. 5 more to go...
Prater is offline
