Best prop slip calculator? >
Old 11-03-2011 | 07:05 AM
Default Best prop slip calculator?
Might be a dumb question but is there a calculator on the net for your particular setup? I.e. brand, length, average load... Something that pertains more to Fountain than other boat? I'm just looking for the most accurate results without having an actual module on board. Thanks for any help.
tbooten is offline
Old 11-03-2011 | 10:09 AM
All you need to know is GPS speed and RPM... then plug it into the equation...
http://go-fast.com/Prop_Slip_Calculator.htm
It doesn't matter if its and ocean liner or a bass boat, slip is slip.
If you are looking for a theoretical calculator for speed, try this one.
http://go-fast.com/boat_speed_predictions.htm
RT930turbo is offline
Old 11-03-2011 | 10:13 AM
Livorsi prop slip gauge
WANTED - set of PSI Superchargers w snouts & adapter plates
fountainfan42 is offline
Old 11-03-2011 | 10:52 AM
thanks guys... 22% doesn't sound to appealing to me...
tbooten is offline
Old 11-03-2011 | 11:07 AM
Dave M's Avatar
Veteran: Navy
That actually worked pretty well for me. Except, I was estimating a little on the weight.
Dave M is offline
Old 11-03-2011 | 11:23 AM
Works very well too. The one i often use.
http://www.mercuryracing.com/propell...calculator.php
So does this.
http://www.heringpropellers.com/prop-slip
And don't forget the on-the-fly version. It's awsome.
http://itunes.apple.com/us/app/herin...472045486?mt=8
A.O. Razor is offline
Old 11-07-2011 | 11:57 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Our new web site will have one that breaks it down into 1/100 of a percent.
We are working hard to get it released soon!
Brett
[email protected]
bbladesprops is offline
