Go Back  Offshoreonly.com > Owners Forum > Powerquest
single-engine enticer >
Old 11-08-2011 | 05:51 AM
Default single-engine enticer
ever seen one of those?...the single-engine enticer 29 was available with a single bbc-at least on paper....i have yet to see one...im asking cause i wouldnt mind owning one if they are around
thanks
pqjack is offline
Old 11-08-2011 | 06:11 AM
Unless it had a turbine it would be a PIG. Boats that size need twins.
POWERPLAY J is offline
Old 11-08-2011 | 08:00 AM
Josh LaFountain's Avatar
Even if it had a turbine it would be a pig out of the hole. It wouldnt start picking up speed untill about 60mph. LOL!!!
Josh LaFountain is offline
Old 11-08-2011 | 09:47 AM
not sure....i have a 27 lazer with approx 625hp,and it runs like a bat out of hell...easily spinning a 25+m...a single enticer cant be that much more heavy??
pqjack is offline
Old 11-08-2011 | 10:25 AM
Ya prob not. My 280 weighs 4800. the 29 prob weighs 52 at most. a stout 525 would make it run good.
Old 11-08-2011 | 10:50 AM
290 weight is 6500lbs
boatnt is offline
Old 11-08-2011 | 10:59 AM
With twins..........deduct 1000lbs for one engine and drive assembly???
and then the weight would be in the 5500 lbs area...
verbi69 is offline
Old 11-08-2011 | 11:06 AM
exactly what i think...single engine 29ft with a 525 or 600hp
pqjack is offline
Old 11-08-2011 | 11:10 AM
ok...whos going to be the 1st to call the factory and order one??
boatnt is offline
Old 11-08-2011 | 11:12 AM
Thanks Verbi....
boatnt is offline
