is there anyone running 6 blade baracuda >
Old 11-25-2011 | 03:05 PM
crayolacrazy's Avatar
Default is there anyone running 6 blade baracuda
I need some info on these props I have aset of 6 blade cncd baracudas from Throttle up , 29 pitch just post it ill keep eyes on it.
crayolacrazy is offline
Old 11-26-2011 | 06:27 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
What do you want to know?
Brett
[email protected]
bbladesprops is offline
Old 11-28-2011 | 08:21 PM
Brett
what kind of boat these will work on ,what prop they compare to thankyou
Old 11-30-2011 | 12:28 PM
Smile
These props were only made for a short time. The propeller was designed to for stern drive applications.
It is a pretty propeller but the reality is it is as much of a marketing ploy as it is effective. The story is that the combination cleaver/round ear blades will provide stern and bow lift. We have played with this theory in the past and have found it to be slightly lack luster.
Determine what the boat needs and adjust a 3-6 blade round ear or cleaver to achieve the desired goals and you there. That being said, this propeller could work fine on a boat with a high "X" dimension or a boat needing stern lift. Compare it to other 6blade Bravo drive props such as the Hering.
One thing I never liked about it's marketing were the blanket statements used like, "we see 3 mph increases".
There are too many variable to state that.
If you have the opportunity, bolt them on. Nothing to lose and knowledge to gain.
Brett
[email protected]
Old 11-30-2011 | 05:08 PM
Brett
I otained a new set of 29,s and they need a home maybe some one will read this an want them. I refuse to run 6 blades on my bravo,s with over 800 hp.
