External steering outside or in? >
Old 11-28-2011 | 07:27 PM
Default External steering outside or in?
If you have the room to install steering rams either inside or the outside...is there a reason why one is better than the other?
flat rate is offline
Old 11-28-2011 | 07:49 PM
1 MAIDEN AMERICA's Avatar
No room for a tie bar if mounted inside?
Better access on the outside?
1 MAIDEN AMERICA is offline
Old 11-28-2011 | 07:50 PM
rgrgoog's Avatar
Never seen it done on the inside. Mine is on the outside and it works great.
rgrgoog is offline
Old 11-28-2011 | 09:27 PM
do it on the outside.
triple 300s is offline
Old 11-28-2011 | 10:00 PM
Formula mounts them on the inside. Doesn't seem like it would matter other then the design of the boat.
diverkr is offline
Old 11-28-2011 | 10:10 PM
rgrgoog's Avatar
Well you learn something everyday. I never knew that.
rgrgoog is offline
Old 11-28-2011 | 10:20 PM
I asked this question before, the response was that it depends if it will clear the tabs or not. Other then that it makes no difference
Perlmudder is offline
Old 11-29-2011 | 06:30 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Pretty sure if one has hyd steering, then it has a tie bar.
US1 Fountain is offline
Old 11-29-2011 | 08:14 AM
Yup.
RT930turbo is offline
Old 11-29-2011 | 02:51 PM
i would want it out. easier to get it and it wouldnt make getting inside any harder than it already is.
soldier4402 is offline
