Electric Hatch lift wiring >
Old 11-29-2011 | 10:23 AM
Default Electric Hatch lift wiring
Anybody know the diagram for a 2 wire motor for a elec hatch lift ? motor not grounded itself...do the flip the ground/power in each direction ? when doing the Hyd steering upgrade under the dash...may have knocked a wire off...mine now only goes up ??? thanks Rob
ezstriper is offline
Old 11-29-2011 | 10:45 AM
Randy Nielsen's Avatar
Check you wiring a two wire motor should just change polarity to go the other direction. Randy
Randy Nielsen is offline
Old 11-29-2011 | 11:30 AM
mcollinstn's Avatar
Double pole - Double throw switch.
Looking at it like this from the back
TOP
A D
B E
C F
BOTTOM
B and E are the motor leads.
A and F are 12v +
C and D are 12v -
MC
mcollinstn is offline
Old 11-29-2011 | 11:44 AM
thanks !!! just what I needed !!!! Rob
Old 11-29-2011 | 12:44 PM
tcelano's Avatar
I also wired in a "secret" switch that kills the hatch independently in case I want to leave the boat in the water with the power on for the bilge pumps.
tcelano is offline
Old 11-30-2011 | 10:51 AM
Wally's Avatar
Were doomed!
The first pic shows a typical setup
The second pic shows a setup i came up with and posted a few years back thats safer...you dont have a long power lead running from your dash all the way back to the engine compartent overloading the wires as most are specs improperly from the factory. And witht he relay setup you get a shorter run from the battery and more power to the hatch ram for it to work better and faster
Attached Thumbnails Electric Hatch lift wiring-hatch-relay-wiring.jpg   Electric Hatch lift wiring-safe-hatch-wiring.jpg
-Wally
Wally is offline
Old 11-30-2011 | 10:58 AM
Wally's Avatar
Were doomed!
If you have some basic electric knowledge you can get VERY creative. My dad is a plant super and carries his keys on a clip he hooks to his pant loop. Few times he has lost them and unfortunatly his car keys are on it. Once it must have fell off in the parking lot as he came outside looking for them and the car was gone! So i installed a latching relay in the starter circuit so you have to push the cig lighter in to latch the relay for 5sec to complete the circuit before the car will start. Even if you have the keys they are worthless unless you know about the cig lighter. And i tapped intot he starter wire right where it goes through the firewall so even if they tried to hotwire the car it would do them no good
-Wally
Wally is offline
Old 11-30-2011 | 01:59 PM
Cool....sounds like you and Tim Allen got together..re wired !!!thanks !!!
Old 11-30-2011 | 02:06 PM
If that were the case he would have a "better" actuator in there with supersized capability and speed
mr3dman is offline
Old 11-30-2011 | 02:12 PM
Oh..ok like a launch pad !!!! could be interesting !!!
