drive &tab pump oil >
drive &tab pump oil
drive &tab pump oil
Old 12-08-2011 | 08:32 AM
Default drive &tab pump oil
Hi all can anyone tell me the correct oil to put in the trim and tab pumps , the tab pump has kiekhaefer wrote on it and says 10/30 or 10/40 is this just motor oil ?? the drive pump oil looks thinner but it does not say on the pump wot to put in it . thanks for any help . paul
paul buckner is offline
Old 12-08-2011 | 09:05 AM
Mercury/Quicksilver power trim and steering fluid #1
or you can use a 30 weight oil that makes you happy. The Merc stuff has anti foaming agents in it and is non detergent.
mr3dman is offline
Old 12-09-2011 | 06:28 AM
i have always used 10/30 never had any issues with it.
pstorti is offline
Old 12-09-2011 | 07:05 AM
seafordguy's Avatar
Me Too....
seafordguy is offline
Old 12-09-2011 | 12:51 PM
X3 and any viscosity will work. Thinner oil will run the tabs/pumps faster.
Griff is offline
Old 12-10-2011 | 05:04 AM
Thanks guys , i did take the time to read up in my SELOC repair manual befor i posted , but it contradicts itself, in one section it says you can use 10/30 oil in a emergency , but drain as soon as poss , then in the maintenance section , it says you can use 10/30 oil and nothing about draining it out?? so i thought i would see wot you guys are putting in the pumps . Its unanimous 10/30 thanks .
Old 12-10-2011 | 08:30 AM
I run tranny fluid.
kvogt is offline
Old 12-10-2011 | 09:25 AM
Originally Posted by kvogt
I run tranny fluid.
+1
Works great
Keith Atlanta is offline
Old 12-11-2011 | 07:38 AM
Originally Posted by Keith Atlanta
+1
Works great
We are talking auto/trans oil , the red stuff ?? , this would be good for me as i allready have plenty , would i be correct in saying its thinner and therefor run the pumps faster ,seems strange that it seems you can run almost any oil in the pumps and no damage or wear, i mean you could'nt run 10/30 in a auto/trans could you ??? i am no expert thats for sure but i do not want to wear out 4 pumps ,thats why i came on here for some advise Thanks all for the impute regards paul
Old 12-11-2011 | 10:20 AM
jbraun2828's Avatar
I use tranny fluid in all 4 of my pumps.
jbraun2828 is offline
