540 carb???
Im not real sure I ordered the afr marine heads from a shop a few years ago new and the cam also they have since then closed down and im not sure the specs. There is like a serial number or something on the side of the heads I can try and get that number if it helps. I dont really know what to do at this point.
So you have no clue what your compression or cam is? Is this a blower motor or N/A.
I made 738HP on my 540 with 315 cnc heads 9.1 compression Edlelbrock victor jr. intake custom cam with a Berry Grant 1000cfm 4150 style carb. I change to a ProSystem dominator 1050cfm carb and a edlebrock 454 victor intake and pick up 3MPH. Dont have any dyno numbers thou.
wow,thats a lot of power for a 9 to 1 motor,what rpm did it peak out at?
