Single or dual ram hyd steering? >
Old 12-16-2011 | 09:48 PM
Default Single or dual ram hyd steering?
Hi all.
24' outlaw, hope to b running low 70s eventually but want full hydralic steering first. Would u recommend dual rams or would 1 be sufficient? I have to safe $$ where I can.
Thnx
Merry Xmas
rivermonkey is offline
Old 12-16-2011 | 10:01 PM
Randy Nielsen's Avatar
My Baja H2X came stock with dual ram I suppose to relieve stress on one small area of the transom. A little more plumbing to run but should handle any mods in the future.Randy
Randy Nielsen is offline
Old 12-17-2011 | 10:21 PM
single ram full hydraulic is better than dual ram add on, if you have the money then dual ram full hydraulic is the way to go
blownhammer2000 is offline
Old 12-17-2011 | 10:56 PM
GPM
Dual
GPM is offline
Old 12-19-2011 | 06:17 AM
dual ! takes the load much better !!
ezstriper is offline
Old 12-19-2011 | 05:38 PM
Originally Posted by rivermonkey
Hi all.
Thnx
Merry Xmas
i have imco and was single but not full single ok if you go full . duall better . i call imco and they told me for a 24 ft boat single will work fine . 1 put a 540 718hp so i went full duall very happy with it. i no some guy that have full single ram and it works good for them .
bajabob is offline
Old 12-22-2011 | 12:52 AM
I put IMCO full hyd on my 30. It came with a hyd assist (brazil valve) on one pump motor but there was too much play at speed. I have a used IMCO single ram " helm control pump " which you will need to convert over to external hydraulic steering. It is in excellant condition and was on my 25 Outlaw which I converted over to dual ram external hydraulic steering.I would go the extra and get a twin ram setup to spread the forces equally on the transom and help maintain the drive in case of a gimble failure. Full hyd is REALLY nice, but you don't have to go that route with your boat. I would call and talk to the experts at IMCO and other mfg's to get a complete picture.
Osrick54 is offline
Old 12-23-2011 | 09:59 AM
I would go dual RAM. I would think the biggest problem with single RAM is the extra load on gimbal ring. All that one-sided force tends to wear out the upper steering pin faster.
Pismo10 is offline
