Ignition module mounting >
Old 06-17-2002 | 07:46 AM
Scott72
Default Ignition module mounting
Finished everything on my motor this weekend except mounting the ignition module (stock thunderbolt IV). Just curious were people are mounting this with aftermarket exhaust (CMI's) with no mounting bracket? I assume the transom (because it does have a ground to the block.
Old 06-17-2002 | 08:36 AM
formula31's Avatar
Thats where I put mine. Ground wire from distributor, ground wire from module and ground wire from block, all attached at the module. 3 good screws with washers.
formula31 is offline
Old 06-17-2002 | 02:25 PM
Mounted mine on the transom also. Just make sure that you ground it properly. I found out the hard way. The module case has to be grounded as well as the ground wire coming out of the module. Run the black out of the module, to one of the mounting screws for the case and then another ground wire from there to the block. Took about 2 days of me saying WTF???? when I just had the black out of the module grounded and not the case.
Griff is offline
Old 06-17-2002 | 03:20 PM
OldSchool's Avatar
Hey Scott , what prop are you going to run? Let me know how you make out.-Craig
OldSchool is offline
Old 06-17-2002 | 04:02 PM
Scott72
Thanks for the reply's, I'll mount it to the transom like I figured.
Craig,
I picked up a 24 pitch Hydromotive quad IV (a deal I couldn't pass up). I'll probably be a little overpropped (with 470 HP give or take) and will need to get it labbed. Really want to get a 3 blade, but I'll start with the 4 blade and work from there. I'll let you know the results (should have it in this weekend, but have to break the motor in).
Scott
Old 06-17-2002 | 06:25 PM
Official OSO boat whore
I mounted mine to the back of the cylinder head.
Cord is offline
Wanted
1
07-22-2008 04:06 PM
shawn
07-16-2008 05:12 PM
tjsmk8
5
07-23-2007 08:03 AM
TROUBLE MAKER
15
07-28-2004 07:00 PM
US1 Fountain
6
05-27-2002 11:32 PM
