hp500 carb to 525 EFI >
Old 12-28-2011 | 03:46 PM
Default hp500 carb to 525 EFI
What is the difference between a blue hp500 carbed motor and a blue 525 besides the intakes and the obvious?
Can you bolt a 525 intake on an hp 500 without a lot of problems or headaches?
I think the 525 has a little bit bigger cam but not sure about the heads?
Will the 525 intake flow better then the 454/502 efi intakes?
baja_brian is offline
Old 12-28-2011 | 05:24 PM
mcollinstn's Avatar
525 has Edelbrock heads.
525 intake is very different than the 454/502EFI.
HP500 Carb (blue) can be either a 502 or a 540 (Bulldog) and probably is a MkIV or Gen 5 block. The 525 is a Gen 6 block.
Cams are similar, but not identical (aside from the thrust bearing stuff).
mcollinstn is offline
Old 12-28-2011 | 08:13 PM
will the 525 intake bolt up to the hp 500 carb heads?
I have the 500 carb motor just sitting in the shop but I really want to go injected since I am going to use it at different elevations a lot this year.
Old 12-29-2011 | 11:53 PM
Carbon Footprint's Avatar
anyone know what heads are on an HP500? are they 088s
Carbon Footprint is offline
Old 12-30-2011 | 02:20 PM
rw40426's Avatar
They are Aluminum Edelbrock heads, almost identical to the Edelbrock marine rectangle port heads except valve stem dia. is different and no merucry casting on them.
rw40426 is offline
