Go Back  Offshoreonly.com > Owners Forum > Warlock
What prop do you like on your cat? >
Old 12-29-2011 | 05:49 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Cool What prop do you like on your cat?
I have a 25sxt and run a labbed 26 bravo I with 1.36 gears.Just wondering if anyone found somthing better.By better i mean faster.
the deep is offline
Old 12-29-2011 | 06:34 PM
Depends I how your hooking up and what kind of power. A 5 blade might help if ur slip numbers are hi. I ran a Maximus on mine and like it.
GTOFFSHORE is offline
Old 12-29-2011 | 08:19 PM
the deep's Avatar
Fast Singles Club
Cool
I have a modified H.P.500.With the current setup it'll run 83 on the gps speedo even on dead flat water.More extensive mods soon to come so i was just wonderin what Warlock cat's seem to like best.I currently have no slippage problems.Like almost everyone else, just got to have mo speed problems!
the deep is offline
Old 12-30-2011 | 08:58 AM
im running a mild 468 with water injected headers, isky roller cam, roller rockers, 750 dp, 088 heads in my boat. maybe 500 hp (prolly less) standard bravo 1 drive w/lwp and nosecone.
ive only got to try a few props on mine before winter set in, hydromotive 28 and 29 and a 28 outboard race prop. all of the props felt very strong on top end but hte outboard prop was a ***** to get on plane. the 29 felt like it was a bit much and was lugging the engine. couldnt be sure becaus the new tach that i had just installed crapped out on me.
the 29 hydro runs 83 on gps. slick glass water, 600 pounds of people and 3/4 tanks of fuel. i only ran the boat once with this prop and this was the only time i have ever gpsd the boat.
most experts seem to favor the bravo props accross the board. i have a 26 and 28 bravo im going to try this spring.
2tonchevy is offline
Old 12-30-2011 | 09:00 AM
what rpm are you turning at 83 mph?
what are your slippage numbers?
Old 12-30-2011 | 09:58 AM
the deep's Avatar
Fast Singles Club
Low end of the scale,4800 r.p.m.'s.I decided to leave the labwork alone cause i'm not done buildin power
the deep is offline
Old 12-30-2011 | 07:28 PM
I would stick with a 4 blade especially if your slip numbers are good. No real benefit from a five until a lot more power. You also need to turn that motor harder. Run it to 5300 for the best power and speeds.
Old 12-30-2011 | 08:07 PM
the deep's Avatar
Fast Singles Club
As per Brad Nickerson i should see a minimum of 650 h.p. with the mods i'm plannin.I'm tryin to do things in a manner as to let myself room to grow.Finished product should produce 850 h.p.Would a maximus be in order at that time?
the deep is offline
Old 12-30-2011 | 11:30 PM
Thats good power the 500's make around 550 in real life so another 100 is 10 plus mph(: 850 will be another world and might not be much fun in a 25. You will get into things like tabs etc. Do you have full hyd. steering? A Maximus will def be a possibility at that power level. What kind of drive are you planning on using?
Old 12-31-2011 | 11:45 AM
the deep's Avatar
Fast Singles Club
Already runnin tunnel tabs and have imco external hydralics.Current drive is a bravo h.p. with diesel internals.I'll cross the drive bridge before i install the blower.You say 850 h.p. may not be much fun in a 25'i don't want to end up with a suicide machine....or do i...
the deep is offline
