Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
Just when you think you have seen it all!!!!! >
Old 01-02-2012 | 04:02 AM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
Default Just when you think you have seen it all!!!!!
http://www.youtube.com/watch?feature...&v=j9Dw__tBhCY
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 01-02-2012 | 07:46 AM
Very interesting idea!
AB From Windsor is offline
Old 01-03-2012 | 07:35 PM
Pwrbt33's Avatar
The idea is good but if only 1 of those deploy and catch the water and throws you around sideways while your starting in the air it wont be pretty.
Pwrbt33 is offline
Old 01-04-2012 | 11:00 AM
Jolley's Avatar
I've seen that before somewhere? .................. Still not sold on the approach ....................... Although it does start the dialog ........
Jolley is offline
Old 01-05-2013 | 10:02 PM
At least someone is thinking. Might not be a perfect concept but it's a start.
Brings up some good questions....
1. How big would those parachute/anchors need to be to overcome the force of the air piling up on the underside of a cat?
2. Once they hook how hard will it put the brakes on! Does the boat now go from a 30 degree up angle smashing back down into the water and possibly submarining?
Again, don't get me wrong I am not ripping on the idea just trying to understand the concept a bit more!
502ss is offline
Old 01-06-2013 | 12:38 AM
With offshore racing, how many times have you seen a boat "almost" go over and not actually go over ? I'm sure many times, like we all have. I would think that most racers, or anyone else, don't actually think they're going over until it's pretty much happened, or else they would have done some other maneuver to prevent it. When you go all out, things happen. If you don't want things to happen, then you don't go all out. I love the idea of better safety, but if it doesn't work instantly and automatically ( like an air-bag on a car ), then I don't believe it's any good. With that said, I hope somehow, someway, someone can make it work.
frankenstein is offline
Old 01-06-2013 | 07:28 AM
Actually this concept is automatic. Apparently based on the video it would use a gyro to determine the boats attitude. I would think that the unit would have to be calibrated so it wouldn't engage until the boat reached a point where it was definetly going over! A driver wouldn't want the device engaging just because he got a little airborne
502ss is offline
Old 01-06-2013 | 09:41 AM
TeamSaris's Avatar
Driver-441
Racer
All I see is a nasty trip and stuff
TeamSaris is offline
Old 01-12-2013 | 05:27 PM
Boat racers do it in canopies.
Lighthouse is offline
Old 01-12-2013 | 08:24 PM
Make it where it breaks free.
Releases after it pulls x amount of pressure, enough to bring the nose down a little.
Then you have stuff floating in the water.
yahoo is offline
