Manual vs Automatic
Old 01-03-2012 | 01:47 PM
Default Manual vs Automatic
Does anyone use a manual when pulling there boat out of the water. And if so how hard is it on the clutch?
s022mag is offline
Old 01-03-2012 | 01:59 PM
First gear is usually low enough that you can just let the clutch out and creep up the ramp. If not put it in 4 LOW and it will take you 25 minutes to get up the ramp in 1st gear
I LOVED towing with a manual trans, the control through the hills and overall performance was awesome.
RT930turbo is offline
Old 01-03-2012 | 02:23 PM
Not an issue at all. Used to drive manual, live in europe, hate automatic.
A.O. Razor is offline
Old 01-03-2012 | 02:28 PM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
I had an '01 Chev 3500 with 8.1 gasser and 6 sp manual. Towed a Baja 302. I liked the manual on the highway, not so much on the back roads. IMO there's enough to worry about when towing without having to shift.
+1 on the low 1st gear pulling out. However, shifting on a steep, long, wet Cumberland ramp wasn't fun with 2WD. Having done it both ways, I prefer auto. Mostly because my wife handles the truck and I do the boat when we launch.
Baja_342 is offline
Old 01-03-2012 | 02:31 PM
Do you have to worry about tranny temps getting as hot with a manual?
What about 4WD systems, does push button or the manual kind on the floor make a difference?
s022mag is offline
Old 01-03-2012 | 02:50 PM
You won't ever have a tranny temp issue with a manual, there is much less friction in the transmission and no torque converter to make heat.
I have had both types of 4x4 systems, either works fine. I almost prefer the manual ones since there are no actuators to fail, and they can be shifted quicker, etc. My current truck is electric though, and I have never had an issue.
Old 01-03-2012 | 03:10 PM
48 ceramic button dual disc clutch, gets really grabbing since theres no slipping that thing under 2500 rpm, so i just use 4 low, 1st and let it take its time.
dodgezilla04 is offline
Old 01-03-2012 | 03:37 PM
seltzer's Avatar
I think todays automatics are so far advanced i see no reason to jump up and down on a clutch all day. I used to drive a 5 speed tow truck and my left leg, knee and hip were dead at the end of the day. Not to mention re-sale value. No one wants a stick.
seltzer is offline
Old 01-03-2012 | 03:47 PM
Old 01-03-2012 | 05:49 PM
seafordguy's Avatar
I sought out a 6 Speed Manual for my F350. Never put it in 4X4 at the ramp - simply let the clutch out and it pulls it right out. I am probably 14k plus....
seafordguy is offline
