3300 cable ends for kiekhaefer controls >
Old 01-06-2012 | 04:34 PM
Default 3300 cable ends for kiekhaefer controls
I can't find anywhere what cable ends for 3300 cables are used for the mercury racing/kiekhaefer controls. Any help is greatly appreciated.
bsullivan403 is offline
Old 01-06-2012 | 05:45 PM
Your Merc dealer can get them.... They're expensive, I think around $80 for the pair.
endeavour32 is offline
Old 01-06-2012 | 06:09 PM
Rookie's Avatar
I made some using using 3/16" heim joints with a 10/32" thread. I can get you some pics if you need a visual. The pin can be punched out, grind a little bit on the inner part of the control away for clearance, insert the heim joint and replace pin. Then put the cables on, then you run them through the boat. I was going to post this in the DIY on a budget form.
I used something like this. You can get them on ebay for $2ea.
http://pitstopusa.com/c-133383-rod-e...-rod-ends.html
Rookie is offline
Old 01-06-2012 | 06:17 PM
here ya go bam marine
845281 CLEVIS, Control Cable $36.87 each
smokin' gun is offline
