Reviews: Jesel Sportsman Shaft Rockers >
Old 01-08-2012 | 10:49 AM
Default Reviews: Jesel Sportsman Shaft Rockers
I'm thinking about making a move to Jesel Sportsman.
Does anyone have any information, good or bad, when using this system?
532CID, Merlin heads, .650" lifts, 5,800 to 6,000 rpm
Dennis
dennyp123 is offline
Old 01-08-2012 | 03:58 PM
Talk to rmbuilder. Shoot him a PM. Good straight info.
ROTAX454 is offline
Old 01-08-2012 | 06:35 PM
You wont go wrong with anything Jesel makes.
JeremyAnderson is offline
Old 01-08-2012 | 06:49 PM
i agree.
mike tkach is offline
Old 01-08-2012 | 09:18 PM
Pwrbt33's Avatar
I like them!
Attached Thumbnails Reviews: Jesel Sportsman Shaft Rockers-johns-blackberry-699.jpg
Pwrbt33 is offline
Old 01-08-2012 | 09:21 PM
who loves them...who hates them?
thanks
Old 01-08-2012 | 09:22 PM
Strip Poker 388's Avatar
Rob
a move form what?
I guess it depends on how ya run it.
Strip Poker 388 is offline
Old 01-08-2012 | 10:00 PM
Originally Posted by Strip Poker 388
a move form what?
stud mounted roller rocker
Old 01-08-2012 | 10:53 PM
i have used the Sportsman Series for well over 10 years on engines up to and over 1400 hp without any problems. Sure, the one piece stands with the Pro Series are stronger, but unless you are running over 600 #'s of spring pressure and over 6500 rpm then there is really no need for them.
Once you put them on and adjust the valves, be sure to verify that the roller is centered on the valve. There is a little play in the stands, so you have to check them. Once they are set they don't really move. So, just be sure they are right the first time and don't worry about it any more.
Eddie
Young Performance is offline
Old 01-08-2012 | 11:15 PM
Eddie
Thanks Eddie...that means a lot coming from you.
