454 bored .60 over >
454 bored .60 over
454 bored .60 over
Old 01-12-2012 | 01:29 PM
Default 454 bored .60 over
so my old 454 is apart and the rebuild begins. its bored .60over and if its stroked to a 496 what will the final cc be? thx
paintman is offline
Old 01-12-2012 | 01:49 PM
if i'm figuring correctly, a 454 stroked to 4.25 and the cylinders punched out .060 will net you a 496. if you keep the stock stroke of 4" and bore out .060 you have a 468. The cc of the quench area will depend on what pistons, valves, head and head gaskets you are using. What cc are you referring to?
mr3dman is offline
Old 01-12-2012 | 02:22 PM
cc i meant cubic, i thought it was bored .60 over then stroked it would have been larger than a 496.
cheers
paintman is offline
Old 01-12-2012 | 02:28 PM
It all depends on what stroke crank you use !!!!
Jeff P31 is offline
Old 01-12-2012 | 02:54 PM
Rookie's Avatar
cheers
A standard bore 4.251" 454 standard stroke 4.00 = 454cu/in
A standard bore 454 stroked 4.25 is 482cu/in
+0.030" bore = 489cu/in
+0.060" bore = 496cu/in
Rookie is offline
Old 01-12-2012 | 03:05 PM
bcfountain's Avatar
Registered User
true,true
bcfountain is offline
