oil thermostats????? >
Old 06-19-2002 | 02:00 PM
dyno's Avatar
Charter Member #655
Default oil thermostats?????
who's running them????I've got an issue with condensation.... the water here is only in the high 50's to low 60's will a oil thermostat help? who's got the best deal? I found one on Summit's site by permacool that is less than $50.....what do you think guys?
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 06-19-2002 | 03:18 PM
traviss's Avatar
Hi Dyno... I am using the perma cool stat from summit.. I installed it when I put my cooler on with the new motor. I like it.. It lets the oil bypass the cooler untill 180-190 degrees then closes and forces the oil through the cooler. I have fast warm ups now. It is a small device can fit mosty anywhere, but you might have to make a bracket to secure it... In my mind its a good piece and works great..
traviss is offline
Old 06-19-2002 | 10:59 PM
Mr Gadgets's Avatar
Charter Member #601
Dyno,
I installed the KE oil stat on my boat.. not sure how it works cause my boat doesnt run. But the idea is a sound one.. you need 190 degrees to run WOT.. so it makes sense. I hope to have a report on this unit within a couple of summers.. Keep an eye out for my progress..
Dick
Mr Gadgets is offline
Old 06-20-2002 | 08:13 AM
dyno's Avatar
Charter Member #655
Thanks guys! Dick I cant wait to here how the check runs ....get a move on will ya! I think that K.E. unit is a little out of my price range.....the permacool one is less than $50 but I'll bet it would be a ***** to install now with the motors in the boat!
dyno is offline
Old 06-20-2002 | 11:22 AM
Cignificant's Avatar
Ditto on what traviss said. I added two permacools last winter. They're inexpensive, simple, and they work.
Cignificant is offline
Old 06-20-2002 | 11:26 AM
Audiofn's Avatar
Charter Member #232
Cignificant you got any pictures of that set up?
Jon
Put your best foot forward!
Audiofn is offline
Old 06-20-2002 | 11:51 AM
Turbojack's Avatar
I set up this year permacool with big eddie marine cooler. I had small mercuser cooler. Now motor oil warms up quicker & pressure never drops below 70psi. before it would go down to 50psi.
Motor was in boat when I did it.
If you do a search you will see where some pictures were even posted.
Turbojack is offline
Old 06-20-2002 | 04:06 PM
traviss's Avatar
here's a pic of mine... click the link cause it won't let me post the same pic...
http://www.offshoreonly.com/forum/sh...threadid=24828
traviss is offline
Old 06-21-2002 | 07:08 PM
mcollinstn's Avatar
I've looked at the permacool unit and like it cause the price is right. Does anybody know, though, whether it has flow restrictions that could be an issue on a big HP motor?
If so, 2 permacools in parallel would work, eh?
mcollinstn is offline
Old 06-21-2002 | 07:25 PM
traviss's Avatar
The perma cool instructions I have said it flows 200 GPM and a maximum off 250 PSI>.
traviss is offline
