Go Back  Offshoreonly.com > Owners Forum > Sonic
Labbed 28P Props >
Labbed 28P Props
Labbed 28P Props
Old 01-27-2012 | 05:21 PM
Plum_Crazy's Avatar
Default Labbed 28P Props
I'm selling a set of pristine 28P Bravos labbed by Bblades for a 31SS with 496HO's. I'm always looking for more speed, so I just bought a set of Herings to try this coming season. I already have two sets of labbed Bravos and one has to go. I saw a best of 76 MPH with these props, but usually ran in the 75's.
http://www.offshoreonly.com/forums/s...ml#post3603265
Plum_Crazy is offline
Old 01-27-2012 | 07:13 PM
My 2007 31 (496 HO) has 26P's stock and I am seeing 72 - 73 MPH at 5000 RPM, could I expect similar numbers with your 28P's ? If so SOLD.
Steve
MDsteve410 is offline
Old 01-27-2012 | 09:37 PM
Plum_Crazy's Avatar
Steve, I can't say for sure what speed you'll see. But, I think you would gain something.
When I first bought my boat, it also had stock 26's. However, it was all over the 5150 rev limiter and only ran 72. Your RPMs seem low. You may want to check the drive alignment. My drives were toed-in quite a bit which slowed the boat. I now run them completely parallel. If you have A/C, you probably have a clamshell pickup under the boat. Turn it so the grate faces backwards. I also recommend using Amsoil gear oil. If you any hull scratches, get them re-gelcoated. Finally, keep all unneccessary weight out of the boat. All these little things add up.
After making some of the above changes, my boat could spin stock 28's to 4900 RPM @ 74 MPH. The labbed props added up to another 2 MPH in optimal conditions.
Old 01-30-2012 | 10:48 AM
Plum_Crazy's Avatar
I've got $1650 in these props, but I'll sell to a fellow Sonic owner for $875 shipped.
Old 01-30-2012 | 07:46 PM
26sonic's Avatar
plum crazy the clam shell under the boat for the ac you said to turn the grate backwards meaning? the grate facing toward the drives ?
26sonic is offline
Old 01-30-2012 | 08:03 PM
Plum_Crazy's Avatar
Yes, there's no reason to face the grate forward and cause drag. A/C is used while sitting still at the dock. IMO, they should have installed the cooling pickup on the transom.
Old 01-30-2012 | 08:32 PM
ROB FREEMAN's Avatar
good point thanks
ROB FREEMAN is offline
Old 02-02-2012 | 08:15 PM
Plum_Crazy's Avatar
Props are sold!
Old 02-12-2012 | 09:44 AM
Just had the oppurtunity to open the boxes and check out the props. They are as new as they come. Thank you for your help.
Jim
overdooinit is offline
Old 05-21-2012 | 12:29 AM
Question
Dan:
Did you run the Herring's yet? I am curious to see how they performed?
Hope all is well with you!
kjberman is offline
