Sealing cylinder head bolts >
Old 06-19-2002 | 11:00 PM
Bo Knows
Default Sealing cylinder head bolts
What kind of sealer is being used to seal up the head bolts on a gen IV 330 / 454 ? Will Permatex work ?
Bo
Old 06-20-2002 | 02:42 AM
Bo last time I did it I used ARP thread sealer and just a touch of ARP assembley lube on the washer and bolt head.
FloridianSon is offline
Old 06-20-2002 | 04:25 AM
I use Permatex High Temp Thread Sealer. Its in a little tube similar to Locktite.
Griff is offline
Old 06-20-2002 | 08:12 AM
formula31's Avatar
Ive used "High Tack" with success. I think its a permatex product too.
formula31 is offline
Old 06-20-2002 | 10:22 AM
ForrestC's Avatar
Default ARP
I'll second my friend from the land of the Gators on the ARP products. ARP thread sealent has lubrication properties that aid in consistant bolt torques. If you do use ARP thread sealents and assembly lube, you should use ARP's torque recomendations to avoid over-tightening your head bolts.
In any event, make sure that the threads are both clean and dry before applying any sealent.
ForrestC is offline
Ken N
8
09-24-2008 02:35 PM
boatnt
03-26-2007 02:30 PM
alecsammy
4
11-11-2006 02:32 PM
speedball
5
05-28-2004 12:28 AM
DanB
5
12-15-2002 05:44 AM
