Worth It
Old 02-03-2012 | 07:05 AM
ROADHOG's Avatar
Default Worth It
Is there any reason to Lab finish SS props for a CC boat? Most CC's are set up not for top end but for all around performance. When after testing several out of the box props and finding one that you feel is the best but still not achieved full RPM's capability would lab finishing be worth to try and achieve the additional 2 to 3 hundred RPM's?
ROADHOG is offline
Old 02-03-2012 | 08:10 AM
I think you kind of answered your own question. I don't think low end performance will change unless you go for different prop. You will probably gain a couple mile an hour. Most cc guys don't really stress over those last couple of mph. But since you are on this site you do(: the only down side would be running shallow with thin blades.
GTOFFSHORE is offline
Old 02-03-2012 | 12:34 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Labbing can consist of trued blades not necessarily thinned blades.
One often overlooked benefit of Labbing in ultra smooth operation. It kind of feels like your running in butter. Also improved throttle response is a great benefit.
Brett
[email protected]
bbladesprops is offline
Old 02-03-2012 | 08:20 PM
As Brett said, it depends on what you want to achive. Labbing is basically customizing the prop to your needs. If you want speed, you can lab for that, but you can also lab for mid range performance, fast planning and so on. As labbing is a customizing of the prop to the boat and particular performance needs, the exact ressults is something you "labber" will advice you about. But a fast labbed prop is not nessecarily a good mid range performance prop. You can do what you want and need. Speed, cruise, accelleration ect. that's what it is about.
A.O. Razor is offline
Old 02-04-2012 | 07:37 PM
Dave M's Avatar
Veteran: Navy
If I was 2-300 rpms shy, I would want to correct that. Regardless of the type of boat. When hot and humid weather comes or you have a heavy load you might be down even more rpms.
Dave M is offline
