Gen6 509 build, hyd roller, 764hp, 732tq >
Old 02-04-2012 | 12:39 PM
Default Gen6 509 build, hyd roller, 764hp, 732tq
I'm re-posting this here. I posted in the general Q&A section, but no one else seems to be albe to see it excpet me. I thought it would be an interesting build...shows the torque potential of something like this with a hyd roller. The cam could be shortened up and bring peak power down some for marine use, but all in all, this is an awesome combination.
Just got back from the Vrbancic Brother's dyno today with some real nice results. This is for a car, but with the installation of a marine oil pan, a little less compresison and timing, and this would be an honest 740hp/700+lb ft. pump gas 509. It made 746hp @ 6100 and 720ft lbs @ 4800 at 32 degrees total timing....a loss of 18hp and 12ft lbs on the race gas.
Gen6 509
4.5 bore x 4.0 str.
Scat std. weight crank
Engine Pro 6.535 rods
Mahle 13cc dome piston, 1.27 ch
11.4:1 cr
AFR 305's fully ported (309cc), 2.25 valve, 103cc chamber
Straub hyd roller 244/248 @ .05 .649/.629, 107
Morel hyd. roller lifter.
Ede. Vic Jr, fully ported , Pro Systems 1000 4150.
Corrected (.04)
764hp @ 6200
732 lbs/ft @ 4900
Scott Foxwell is offline
