edelbrock alum head opinion >
Old 02-05-2012 | 09:35 AM
Default edelbrock alum head opinion
hi all in the process of rebuilding my old 454, stroking it and have a chance to get a set of these heads at a good price(new, but never used) - any feed back, pros or cons....dont have the flow # yet from seller but should soon
thanks pat
paintman is offline
Old 02-05-2012 | 09:47 AM
i have installed them on several marine engines,they are better than stock gm heads and with aluminum,you can rwn more compression,because aluminum dissipater heat much better than cast iorn.they also flow way better than stock gm heads,and they are priced right.i say go for them.
mike tkach is offline
Old 02-05-2012 | 09:54 AM
had a set on my 454...they flow decent numbers,according to my local hi-perf guy...engine made 515hp,with other mods...i was very pleased with the performance
pqjack is offline
Old 02-05-2012 | 11:03 AM
They don't like salt water on a Gen V VI block, Water passages will not line up ( round hole on the head , oblong hole on the block ) salt water sits on top of head gasket and eats up uncoated alum.
formula 382 sr-1 is offline
Old 02-05-2012 | 11:11 AM
Craney's Avatar
How do the water passages line up on the gen IV blocks ??
Craney is offline
Old 02-05-2012 | 12:28 PM
bottom line is ,no bare aluminum head likes salt water,no matter what block they are on.
Old 02-05-2012 | 12:55 PM
ok so do the different gernerations of blocks have different water passages- if so i assume you will have to get the correct generation of head and match up accordingly.....
paintman is offline
Old 02-05-2012 | 01:38 PM
Read the post, Eats up the uncoated part of the head !!!!
Old 02-05-2012 | 01:43 PM
Old 02-05-2012 | 01:45 PM
If I'm correct I believe the heads will work but you have to be sure you have the correct gasket. I believe you use the gasket for the block you have. What block do you have?
picklenjim is offline
