Water/Methanol injection >
Old 02-09-2012 | 05:33 PM
Default Water/Methanol injection
I am looking in a water/methanol injection kit for my blower engine. The engine is a upgrade 525sc with aluminum head 8:1 comp ratio stock merc ingnition 35* at 4500 with a 2.45 ratio puley on the 177 blower, With that setup i think that is a good idea to install a water/methanol injection to keep the engine safe and keep the 177 blower more efficient.
Anyone have try or have some experience with water/methanol injection setup???
supermx96 is offline
Old 02-10-2012 | 08:53 PM
Any idea on that setup?
Similar setup have been tested?
Old 02-11-2012 | 05:54 AM
Where's runninghot when you need him. You ought to search methanol injection on the board and pm some of the guys who are doing it. They will be able to tell you what you need. No one around me is doing it. Good luck, thats a nice engine combo.
SkiDoc is offline
Old 02-11-2012 | 09:29 AM
Call Rudy Dryden @ 302 367 4962
He is in Delaware, dont know where you are located but I am sure he would talk to you about it.
He has a few sets running around. Did RunningHots Meth injection as well as a few others.
Philm is offline
Old 02-11-2012 | 09:35 AM
I use one from cooling mist
ezstriper is offline
Old 02-11-2012 | 06:04 PM
I am from Quebec,Canada it is hard for me to talk by phone because i speek french and my english is litle hard by phone but thanks for the info .
Old 02-11-2012 | 07:39 PM
GPM
The timing seems high for a blower motor, how much boost are you running ?
GPM is offline
Old 02-10-2014 | 02:11 PM
Did you ever get an answer on this question. I would also like to add meth mix on my 525sc when I cant find 93 gas and need to run 89. Im in ontario
snapcracklepop is offline
Old 02-10-2014 | 03:21 PM
A guy near me with a trip 525 sc fountain uses torco octane boost and pump 89, 4 seasons without an issue.
Unlimited jd is offline
Old 02-10-2014 | 03:58 PM
seems like a blower upgrade and superchiller is a better investment than just adding a bandaid to the hot air blowing stock 177
dsmawd350 is offline
