Wanted Merc Speedmaster V drives >
Old 02-12-2012 | 08:58 AM
aex's Avatar
aex
Default Wanted Merc Speedmaster V drives
Wanted pair of Mercury Speedmaster V drives . Call Jimmy 401-942-2400 weekdays
http://www.offshoreonly.com/classifieds/wanted_v_five_merc_drives-o43929-en.html
aex is offline
Old 02-12-2012 | 09:24 AM
Do you need gimbles also?
Unlimited jd is offline
Old 02-12-2012 | 09:33 AM
aex's Avatar
aex
No . What do you have ?
aex is offline
Old 02-12-2012 | 09:37 AM
2 ssm gimbles, were new old stock in boxes put on and used less than 20 hours there like new, and 2 ssm3 drives. Not 3as
Old 02-12-2012 | 08:12 PM
marinetrans's Avatar
Walter Collins " TKO" has a set of beefed-up 4's, low hours, call him at Great American Pub in Raynham/Taunton,MA.
marinetrans is offline
Old 02-12-2012 | 08:47 PM
aex's Avatar
aex
I kept cracking the lower gear cases on the IV drives a few inches up from propshaft . When the fives came out I never had another problem .
aex is offline
Old 02-12-2012 | 09:07 PM
aex's Avatar
aex
I've just been offered a fresh pair by an Apache guy . He sent me photos that just don't look right . There's evidence of a leak and they've got blue Cal Custom 80's pinstripes which strikes me as odd . Check these photos out please .
Maybe it's just me . Too worried about getting screwed .
Attached Thumbnails Wanted Merc Speedmaster V drives-picture-073.jpg   Wanted Merc Speedmaster V drives-picture-074-1-.jpg   Wanted Merc Speedmaster V drives-picture-082.jpg
aex is offline
Old 02-12-2012 | 09:12 PM
aex's Avatar
aex
I'm looking at these pictures blown up and I'd swear these are IV uppers with V lowers bolted on although looking at the lowers from these photos it's hard to tell what they are exactly .
aex is offline
Old 02-13-2012 | 11:02 AM
RMPRam's Avatar
I enlarged the pictures and it is extremely difficult to tell, as they are so dark, if the upper housing is one of the latest design, #5 housings. The last design #5 upper housing was "smooth" on the side where the 6 stud holes are. The early #5 and all the #4 upper housings were "scalloped " around these stud boss's. A #5 lower case might have a V stamped in it immediately in front of the wear plate area. The true way to tell is separate the upper and lower housings and look at the front verticle shaft. A #4 and early #5's were polygon in shape. A true #5 will have a splined front verticle shaft. Also the spur gears on a #5 are 1" in thickness. Also look at the OD of the trim pin hole in the rear of the upper case. On a #5 it is 1" in comparison to a 7/8" pin for a #3 or #4 drive.
Hope this helps.
Gary Kollofski
612-247-7081
RMPRam is offline
Old 02-13-2012 | 11:24 AM
Paul is asking $18k for the pair of #5's he states that they are fresh rebuilds from speed master...
adk61 is offline
