how do I know if I need a new gimbal bearing (trs drive/borg warner trans) >
Old 02-15-2012 | 12:17 PM
Default how do I know if I need a new gimbal bearing (trs drive/borg warner trans)
I am freshening up the drives on my boat and am ordering new trim position sensors, indicator cables, hydraulic trim lines,etc
The boat was meticulously maintained, but I have no idea when this stuff had been serviced or gone through. the boat worked perfect in the water last summer, and not sure if its worth the extra hassle to have the gimbal bearings replaced
thanks
-Darko
darkostoj is offline
Old 02-15-2012 | 12:22 PM
when it locks up and heats up so much while your running that your driveshaft snaps and blows through your bellows, then the boat starts sinking. Atleast thats when I replaced mine........
302Sport is offline
Old 02-15-2012 | 12:27 PM
i'm sorry about hear, but that was really funny
hmmm, so in other words its good preventative maintenance!
Old 02-16-2012 | 07:15 AM
If the drives off and you have no idea if the bearing has ever been replaced, replace it. Its not an item you can replace with the boat in the water how about the bellows?
boomer is offline
