Teague Switchable muffler question >
Old 02-16-2012 | 02:36 PM
Default Teague Switchable muffler question
I have two sets of Teague switchable mufflers. I need to install a relay for the solenoids. Can anyone make a suggestion as to what to use? Would one be enough for all four mufflers or should I use one per set?
endeavour32 is offline
Old 02-21-2012 | 02:08 PM
No one has any input? I guess I'll have to call Teague!
Old 02-23-2012 | 01:06 PM
MnFastBoat's Avatar
Charter Member#157
I would get the soleniod from Teague. Pricey! Last one I bought was over 4 years ago and it was like $60
It is basically a marinized Ford starter soleniod. But more heavy duty!
I have 2 pairs on my boat and one went out. Tried one from Napa and it only lasted a couple trips out.
Bought the correct one from Teague and it has been there for a few years.
OOPSSy, you need a relay, I was thinking Soleniod. Sorry
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 02-23-2012 | 01:10 PM
Coolerman's Avatar
PF Marine
Has the water patrol ever bugged you about switchables? They've stopped us a few times, and kept trying to search for where our switchables were (we have full time mufflers, not switchables).
Coolerman is offline
Old 02-23-2012 | 04:20 PM
From what I can see in the pictures on the teague site, it looks like a trim pump solenoid. The solenoids on the actual mufflers are working fine.
Old 02-23-2012 | 05:47 PM
I was gonna recommend a merc trim pump solenoid, i think they are like 25 bucks from merc?
MILD THUNDER is offline
Old 02-23-2012 | 06:38 PM
1 solenoid will operate 4 tip's as per the teague wiring diagram . If you do not buy the proper one they will over heat and burnout .
Jeff P31 is offline
Old 02-24-2012 | 04:23 AM
bought one from Teague runs all 4,, use heavy ga. wire good solder fittings and it will last. I've had for 4 years.
silent lucidity is offline
Old 02-24-2012 | 07:25 AM
OK,
Thanks Guys. I order it from Teague and save myself the headache of being penny wise and pound foolish!
Old 02-26-2012 | 04:42 PM
MnFastBoat's Avatar
Charter Member#157
Yes they have!
I would say 95% of the time i leave them closed.
I still have the y-pipe in mine from the original diverters.
I just removed the internals and welded the holes.
I still get the flow out the transom with some diverted down the pipes. I feel this really helps keep the main bark off the noise but still allows some pressure relief
Typically they do not bother me all that much, but then agian I really have not had much time in the boat in the last several years.
