What to do if your hatch motor quits?
What do you do if your hatch motor quits and the hatch is down? Mine hasn't yet, but I would like to have a plan if that happens. I have been looking at mine (2002 Lavey 29 Nu Era) and I cannot see a way to pull the pin if you needed to. I'm thinking of drilling a access hole in the top and putting a vent on it with screws. So it could be removed to get at the hatch pin. Any other ideas on what you guys are doing?
My lift cylinder is in a sliding sleeve and there is a recessed handle in the deck. The connection bolt in the sleeve has been removed so I can lift the hatch even if I lose power. It is very heavy and I had to do it once because my grandson lifted the hatch to show some friends the engine. I showed him where the switch was after that.
The plug will be located right next to the battery switch.
You can either hook a battery to it or a charger. If you use a charger, that plug is only to be used in order to get the hatch up, DO NOT use it to charger the batteries.
Mine did not come with this connector/fitting but I ordered/made one that is great if the electric motor is working. BUT.... What if the motor actually QUITS!!! Like will not work even though you have electrical power. My motor doesn't sound good and I don't see any way to pull the quick pin that attaches the ram to the hatch. Unless I'm missing something???? I don't want to be out on the water and not be able to get into the engine compartment because the electric motor on the ram quit working.
Exactly,Correct!! has anyone figured out how to get into the engine compartment if the hatch motor QUITS. Due to something other than an electrical problem. I see this as a BIG PROBLEM! I'm thinking of drilling a 4" hole in the top/back of the middle headrest /engine intake vent and putting a round white soffit vent in it so if I need to I can pop the vent out and pull the quick pin and be able to lift the hatch by hand. Any other ideas on how to get to the pin. I don't see how.
Im looking for a pict- my big Lavey has what Quent is describing an external connector for power, but if the lift quits thats an entirely different problem.
My little Lavey has a pass through behind the seat you can reach inside and pull a pin on each side of the lift (its a very nice pin actually)
Ive had an electric hatch lifts for 20 years and never had the hatch lift quit.Im sure it happens though.
Uncle Dave
