What to do if your hatch motor quits?
Im looking for a pict- my big Lavey has what Quent is describing an external connector for power, but if the lift quits thats an entirely different problem.
My little Lavey has a pass through behind the seat you can reach inside and pull a pin on each side of the lift (its a very nice pin actually)
Ive had an electric hatch lifts for 20 years and never had the hatch lift quit.Im sure it happens though.
Uncle Dave
Uncle Dave
if your hatch has a sunpad on it, should be easy to put a screw in or popout style deckplate near where your ram connects under the hatch, and a quick relese pin at the top of the ram. no tools or power needed to raise hatch. i have seen many boats set up that way, of course only looks good if boat has a sunpad, to cover the deckplate
If your motor is making a noise or sounds funny just change it. Don't drill a hole, don't spend to much time thinking about this problem that doesn't exist. I've had a few boats and none of them every had a issue with getting the hatch up. I think is a non-issue. The bigger worry should be how many hot chicks can you get in your new 29!!!!!!!
