drive shower >
drive shower
drive shower
Old 02-24-2012 | 01:59 AM
Default drive shower
What is a drive shower? And what type of situations calls for them.
conneroutlaw is offline
Old 02-24-2012 | 02:34 AM
Cools your drive
When your on plane the majority of your drive is out of the water and the only source of cooling is from the raw water going to your engine. The shower "showers"your drive with water to cool it. Any drive would benefit from cooling
Yoda_Man is offline
Old 02-27-2012 | 07:21 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
There are a couple different designs. Here's what I run. May not work if you have external steering. Just Google Bravo Drive Shower.
Baja_342 is offline
Old 02-27-2012 | 10:21 PM
JasonSmith's Avatar
IMCO makes a very nice shower. Looks very nice & will clear any steering & tie bar or whatever.
JasonSmith is offline
Old 02-28-2012 | 04:57 AM
The Simrek showers are nice imo and they work with IMCO and Latham steering. I like the fact that you don't have to drill the drive. A few have expressed concern about it not cooling the top cap, never a problem I've noticed. On the other hand, I've seen top cap style systems not being able to cool the rest of the drive. I guess it's a question about personal preference.
A.O. Razor is offline
Old 02-28-2012 | 10:03 PM
+1, i've had both of these and could not tell a difference, drive stays clean, went with simreck this time because of clearance issues with swimplatform and the no drill install
blownhammer2000 is offline
Old 02-29-2012 | 07:07 AM
The need and effectiveness of a drive shower is debatable however....I don't run one. I have yet to see positive proof via a drive temp gauge of any significant drop in oil temperature. Also, there is a lot of water flying around back there at speed so the drive is not really dry.
thirdchildhood is offline
Old 02-29-2012 | 08:22 AM
Knot 4 Me's Avatar
I run a Simrek. If nothing else, it keeps the calcium deposits off the drive.
Knot 4 Me is offline
Old 02-29-2012 | 01:11 PM
The fact that you see calcium deposition is proof there is enough heat to evaporate large amounts of water causing the white chalk accumulation.
08 fastech 292 is offline
Old 02-29-2012 | 04:39 PM
yuuuup!!!
