cleaning corroded electrical connectors...coca cola? >
Old 02-28-2012 | 10:35 PM
Default cleaning corroded electrical connectors...coca cola?
Just wondering whats the best way to clean corroded terminals on connectors? I got a few that have white powder and a green film on them. I was talking to someone who set to soak them in coca cola and thought it was kind of silly. Also heard of using vinegar. Any thoughts? I really like the idea of dipping it in the coke because it would clean the corrosion out of the female terminals that you can't get a brush into
darkostoj is offline
Old 02-28-2012 | 10:45 PM
coke will clean corrosion off battery terminals.. i dont personally use it they make corrsion spray get your a few wire brushes etc. to clean em afterwards
jason y is offline
Old 02-28-2012 | 10:52 PM
pb blaster works great,after you get it cleaned up,put some dielectric grease in the terminals.
mike tkach is offline
Old 02-28-2012 | 11:07 PM
Product called deoxit!
Waveform is offline
Old 02-28-2012 | 11:50 PM
How about an electrical contact cleaner?????? I am sure you can pick some up at radio shack. Once clean you can use WD-40 or a similar product to protect.
low_psi is offline
Old 02-29-2012 | 04:36 AM
Baking Soda and water, flush good, dry and light coat of grease. Works great.
Rattlesnake Jake is offline
Old 02-29-2012 | 08:26 AM
This.
Wayniac is offline
Old 02-29-2012 | 10:21 AM
Too Stroked's Avatar
As somebody else said, remember that cleaning a corroded terminal is only half the fix. The terminal corroded for a reason. In many cases it's because the protective plating broke down and allowed the corrosion to start in the first place. Now it's gone and things just corrode even faster.
So once you get the corrosion removed, you need to prevent it from coming back. Although a new terminal might be the ultimate fix, products like Fluid Film do wonders for preventing corrosion.
Too Stroked is offline
Old 02-29-2012 | 11:24 AM
SpeedDoc's Avatar
Charter Member # 302
They make a spray that you use after you get them clean that protects them, it is made to protect the battery terminals & other unprotected electronic connections.
SpeedDoc is offline
Old 02-29-2012 | 11:30 AM
Dielectric grease made by a # of manufactures. NAPA has it.
