TRS Swivel pin leak!
I'm leaking water from both of my swivel pins at top of gimbal pin. There is no play and there are tight. It only started at the end of last season. I'm running full hydraulic external steering, no internal anymore.
Is there a seal there? Where do I get it?
I may end up just getting new swivel pins too. They are the U bolt style.
Richard
Richard
Looks like your going to need parts 3, 4, 5, 6 in this diagram.
http://www.perfprotech.com/store/ass....aspx#assembly
Hopefully you won't need the swivel pins. Their like $320 each. Part 12 in this diagram.
While it's apart you may as well replace the lower bearing and seals. Parts 2 (2) and part 3.
Be sure to use Merc manual #5 when doing this. The nut which tightens down on the swivel pin against the top of the steering lever lifts the gimble ring to set the up and down play.
Getting the upper pins out were a serious pain. Both the upper and lower pins made the bellhousing hinge pins seem like a day in the park. Again, lots of PB blaster and heat is what finally got mine out. Good luck, Randy
I have the manual in both hard copy and PDF. PM me an email address and I will try to send it to you. It's 57MB which is too large to send regularly so I will have to send it through some type of compression program.
Mine isn't leaking I just need to get it off so I can put a new bushing in the bottom pin!
