looking for a broken #6 prop >
Old 03-01-2012 | 11:57 PM
Default looking for a broken #6 prop
im looking for a #6 prop that is damaged beyond repair. doesnt matter how many blades it has , can be cracked, missing baldes,doesnt matter.
JJONES is offline
Old 03-02-2012 | 05:51 AM
I have to ask,.... For what? Paper weight?
A.O. Razor is offline
Old 03-02-2012 | 09:01 PM
OL40SVX's Avatar
How much you looking to spend? I got quite a few
OL40SVX is offline
Old 03-03-2012 | 12:10 AM
i dont want to spend a lot, im going to make a prop shaft wrench, what do you want for the worst one you have?
JJONES is offline
Old 03-03-2012 | 11:32 AM
If you wanted to send me a small chunk of material, I can bore it to size & cut the splines in it for you. Then you could weld or attach whatever you wanted to make it into any wrench?
Thanks, Tim Bostic
Hoss Marine Props
hossprops.com
Tim Bostic is offline
Old 03-04-2012 | 02:05 PM
Thanks tim, can you send me your email so i can get your address. it just needs to be a small chunk of metal,doesnt have to be stainless, so i can weld on a handle. i will send you some.
JJONES is offline
Old 03-05-2012 | 03:26 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
I have #6 hubs as well if you don't want to machine or broach splines into raw metal.
Also curious what you need the splined part for. Rebuilding #6's?
Brett
[email protected]
bbladesprops is offline
Old 03-09-2012 | 12:07 AM
yes,rebuilding and dry sumping six drives. full dry sump. thanks
JJONES is offline
Old 03-09-2012 | 10:32 AM
Smile
Sounds good.
Are you taken care of?
Brett
[email protected]
Old 03-28-2012 | 08:46 AM
I never received the material?
Did you get fixed up or do you still need some help?
Thanks,
Tim Bostic
hossprops.com
