New boat to me what oil and drive oil to use?? >
Old 03-08-2012 | 07:38 PM
Default New boat to me what oil and drive oil to use??
I live in michigan and getting ready to get the boat out for summer. I just bought the boat last year and am doing first oil changes and drive oil changes on it and wondering what to run?? It is a 94 Scarab 29ft with twin 350 with alpha one gen 2 out drives. I like to buy my oil at walmart if possible because its cheeper but didn't know if they carry anything that will work or not this being only my second boat. Please tell me good brands and weights to run. Same with lower unit oil. I am planning on doing oil changes, drive oil changes, fuel filters.
I run castrol 20w50 oil in my 383 stroker in my mud/sand truck will this work?
chevytrucks94 is offline
Old 03-08-2012 | 07:57 PM
cigboat1's Avatar
Cool
Mobil 1 15W- 50 for the motors....... Wal mart will have it this spring in five qt containers or you can buy it at Autozone ,its on sale now along with filter.. Merc.Syn. for the drives. Dont skimp on the oil!!Good luck
Jim
cigboat1 is offline
Old 03-08-2012 | 08:53 PM
How much of your new boat?
glenngac is offline
Old 03-08-2012 | 08:56 PM
the castrol 20_50 is good,i like the amsoil lower unit lube for thedrives,and its cheeper than the merc lube.
mike tkach is offline
Old 03-09-2012 | 02:43 AM
You can use the Quicksilver High Performance gear lube at Walmart. It is the same as Merc HP gear lube and about 1/3 less $$.
Griff is offline
Old 03-09-2012 | 06:22 AM
i like straight weight oil depends on water temp but 40 or 50 weight
mach1magnum is offline
Old 03-09-2012 | 06:34 AM
I like the Castrol 20W50...especially if the motors have some time on them. There is an argument for not switching to syn if the motors have a lot of fossil oil time on them...stick with what works for you.
The Amsoil is a good product...Teague swears by it. I'm taking a long hard look at Lucas for my re-built Bravo's...you might consider Lucas...all their stuff is "Top Drawer".
sprink58 is offline
Old 03-09-2012 | 08:25 AM
I like Amsoil, it won't break down as fast as conventional oil. As for oil weight I like straight 40. You need to remember the W stands for winter weight. We don't use our boats in the winter so there is no need for multi-grade oils in a boat. I like Amsoil in the drive as well but as stated the quicksilver HP oil at Walmart works well too.
endeavour32 is offline
Old 03-10-2012 | 08:35 AM
Royal Purple straight 40 in the engine and Royal Purple Max Gear in the drive.
Padraig is offline
Old 03-15-2012 | 10:05 PM
Ok now i have had a few people tell me rotella 15w 40 diesel oil. Is this true and has anyone ran this and had good and or bad luck with it in their boat. I run it in my duramax and am happy with it but didn't know about boat application
