Feed Back on GLM Aluminum Exhaust for SBC >
Old 03-09-2012 | 06:44 AM
Default Feed Back on GLM Aluminum Exhaust for SBC
I am almost sold on these and am looking for user experience and also who has the best price on these? Any bracket/accessory fitment issues.
A Miami Distributor has them A~Z for $799.00/pair...is there a significantly better number on these anywhere?
sprink58 is offline
Old 03-09-2012 | 10:26 AM
I've used GLM's for a couple years with no issues. Just make sure the mating surfaces are smooth.
Check on eBay. I bought the last 2 sets on there.
f_inscreenname is offline
Old 03-09-2012 | 10:39 AM
BUP
I sell these as well. never had a app in saltwater but all the freshwater apps have had no problems for about 7 years now.
I would use the Mr.Gasket exhaust manifold gasket as we had better luck with them than anyother marine exhaust manifold gasket on the market.
I can see what better pricing I could offer if you really wanted this app. just let me know thanks John.
BUP is offline
Old 03-09-2012 | 11:00 AM
i don't know how they are gonna hold up in salt. will find out next year or two. dennis moore on eBay. mooreperformance. they are only a little more money than iron, and half the weight. i am tempted to convert to closed cooling and run my stainless risers...
dereknkathy is offline
Old 03-09-2012 | 11:01 AM
Wink Salt + Aluminum = possible issues
My opinion is that they are aluminum and I know they are less expensive than most marine replacement manifolds. My thought here is unless you have closed cooling that includes the manifolds you are going to have to carefully flush WELL after every use and then I still don't think you will see more than maybe 2-3 years before they have a possible issue and that leak can cost you engines so be careful.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 03-09-2012 | 11:17 AM
I run in brackish water and flush after every use. Have one set that is 6 years old and still look great inside (had them apart last summer for other reasons). Use Merc SS risers to top them off.
Old 03-09-2012 | 11:28 AM
i have a nice set of merc staimless risers asking 225 plus the ride should ship for $20 flat rate box 2 to 3 day delivery time
Attached Thumbnails Feed Back on GLM Aluminum Exhaust for SBC-stainless-riser.jpg
mach1magnum is offline
Old 03-09-2012 | 01:15 PM
Thanks...yes see what you can do on 2 pair of these for Small Block Chevy. The 2 main reasons I want to use these is increased service life in salt water and weight savings. If I am not getting any additional service life over the cast iron I want go to aluminum...they are almost 2 x the cost.
I am anal about the flushing and will even use a salt neutralizing product.
Thanks for all of the response.
sprink58 is offline
Old 03-09-2012 | 10:07 PM
BUP
Just checking to make sure we are the same page. You want to 2 complete sets of alum. GLM exhaust manifolds, risers & hardware meaning 4 manifolds - 4 risers and the rest to complete the 4's.
Do you need 3 inch or 4 inch risers. Also do you want the standard GLM exhaust manifold gaskets that comes with the kit or do want the Mr. Gaskets. Mr. Gaskets a bit more cost - just checking and I will get back to you up here and or if you want to call 817-658-7721 cell. Thanks John
BUP is offline
Old 03-09-2012 | 10:12 PM
I need complete A~Z with risers for 2 engines. Figure them 4". Figure the best gaskets.
Thanks..John
sprink58 is offline
