Drive tie bar setup
Ok, measured my drives and found that they are set up with the props closer than the front of the drives \ / . Though my props turn out. Is this right? I could see a theory that the props push in going forward?? Any thoughts fellow cult peeps?
If Props are turning out 1/16 - 1/8 toe in so the prop torque will pull them straight at speed . If I remeber correctly, bunch of past threads on it in here.
