2007 F-350 Issues, Need Help
Old 03-14-2012 | 03:08 PM
Registered User
Default 2007 F-350 Issues, Need Help
Does anyone know if Front Dana 60 High Pinion 3.73 Gears, will work in a 2007 F-350, Diesel, 4x4?
Had a little mishap with a F-350 ( doing a burn out ) and screwed the truck up...So tring to see if the above parts will work or not?
Thanks!!
Powerboat713 is offline
Old 03-14-2012 | 06:17 PM
articfriends's Avatar
are you trying to put front high pinion 60 gears in a std rear, if so don't think its going to work, need more details. Never seen a ford 1 ton Diesel with ONLY a dana 60 in the rear so please clarify, Smitty
articfriends is offline
Old 03-14-2012 | 06:29 PM
We have a forum for trucks...
Catmando is offline
Old 03-14-2012 | 09:37 PM
did ya bust it up or the axle shafts and such. I was able to find replacement shafts for my rig where the dealer wanted the whole axle inner and outer shafts when i only needed the outer shortys....
JPD Motorsports is offline
Old 03-15-2012 | 01:42 PM
Registered User
Truck is being fixed, had to get parts from FORD...
Thanks!
