Jet help
I run a ZZ502 in my 22 Eliminator Daytona with 325 AFR heads 104cc, good size cam (don't have cam specs in front of me) with a Holley 950 HP. Every since I put the heads on this motor its been a real b**ch to jet. I'm running to fast to turn the key off at WOTand getting color in the plugs with the gas we have this day in age sucks. I thought maybe somebody may have a suggestion.
after a hard run,come to a normal stop,pull some plugs,clean soot of with some lacquer thinner,the coloring of the plugs,if their is any,will not be washed away from the thinner.if its white,jet it up and try it again.
With modern fuels, it is unlikely that you will see hardly any color on the porcelain. Fuels burn very clean and don't leave any color. You are better off to look at the base circle of the plug.
When my motor was stock that's about the same combo I ran with my 850 but now I turn 6000 rpm and I go white to black with no in between. The plugs stay white till I jet so high the motor falls on it's face.
