37 AVH Question >
37 AVH Question
37 AVH Question
Old 03-17-2012 | 10:01 AM
1980Condor460's Avatar
Default 37 AVH Question
If water gets in the cabin under the floor- how do you get it out? I have looked at a couple and have not seen drains at the step. Can water get to that point?
I have been looking at them and am considering purchasing one. Thanks for the help.
1980Condor460 is offline
Old 03-17-2012 | 10:15 AM
ActiveThunder's Avatar
There's a bilge pump in there.
ActiveThunder is offline
Old 03-17-2012 | 10:26 AM
That makes it easy. I look forward to joining the Cult......
Old 03-17-2012 | 11:16 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It's more fun to back up real fast, and it will shoot out of the bow cleats.
Sydwayz is offline
Old 03-17-2012 | 01:10 PM
Well I am Ready to Rock......
First stop - Smith Power.
Old 03-17-2012 | 06:31 PM
How do you access the forward bilge pump? Mine is on a timer that whenever cabin power is on it cycles 5 mins or so. Supposed to be that way? Why not direct wired with a float? Thanks
bonesmalon is offline
Old 03-17-2012 | 08:31 PM
It's a pricey little computerized bilge pump that is self contained. Where it is tough to get to vs. the bilge I thought less stuff to break was better. Yours should be an access hole under the pirelli on the lower step.
If you want to put a switch in you will probably find the wire running up to the galley panel.
Old 03-17-2012 | 08:45 PM
Gladhe8er's Avatar
Congrats on the pick-up! That boat has been discussed a lot lately. I saw it in KW and it looked good.
Gladhe8er is offline
Old 03-18-2012 | 09:19 AM
Wow that was fast, when you said you were looking you meant it! Cool.
I had a 22 DONZI that had a drain plug in the step,,,,,,,, amazing how much water gets there.
Wildman_grafix is offline
Old 03-18-2012 | 12:05 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Congrats on the new boat!!
The race boat and a couple others have had drain plugs in the step, but they are not needed. As a backup to the bildge pump, you can stick a shop vac over the thru-hull and pull the water out that way as well.
I have mine wired to the power switch for my water pump. I didn't like it turning on every couple minutes when the cabin power was turned on.
Sydwayz is offline
