drive not raising
Old 03-18-2012 | 07:45 PM
Default drive not raising
My trim pump just goes down and clicks when i push the up button. Any ideas
fountain44 is offline
Old 03-18-2012 | 07:58 PM
solenoid is bad there are two one for up and one for down
kidapache is offline
Old 03-18-2012 | 08:01 PM
thanks
Old 03-18-2012 | 08:07 PM
put some viagra in the oil res,it will go up,if it stays up more than 4 hrs,call a merc tech.
mike tkach is offline
Rookie's Avatar
Also check you wires, loose connections and corrosion will do the same thing.
Rookie is offline
Old 03-18-2012 | 09:32 PM
+1 I had that issue and didnt think to check the connections. Diving underwater at the dock in 56 degree temperatures and taking pieces off the outdrive to be able to manually tie it up and get it on the trailer is not fun at all!!!
DirtyJerz is offline
Old 03-18-2012 | 11:23 PM
Come on Guys. Really You can't jump a solenoid before You jump in cold water??? Love the viagra joke Mike tkach. You just have to love real boaters.
akaboatman is offline
Old 03-18-2012 | 11:51 PM
check your wires & for loose connections
Pot of Gold is offline
Old 03-19-2012 | 07:17 AM
Sorry Im not a "real boater" like you! Just sharing my silly experience Hence the reason why I said to check connections also.
Old 03-19-2012 | 08:28 AM
Audiofn's Avatar
Charter Member #232
Next time take a quarter or screwdriver, key... and put it across the two large posts. The drive will go up and get you out of a jam.
Put your best foot forward!
Audiofn is offline
