Sea trial on Saturday results.... >
Old 06-24-2002 | 07:34 PM
Waterfoul's Avatar
Gone Fishin'
Unhappy Sea trial on Saturday results....
Motor runs well. Jumps on plane. Oil temp is an issue though.
It seems my oil may be flowing past the bypass valve in the filter adapter. Saw 260 degrees in a short cruise never exceeding 3800-4000 rpm or so.
Gonna work on it tomorrow. I need a day off from tinkering with the damn thing.
Waterfoul is offline
Old 06-24-2002 | 10:14 PM
Good to hear its running well...........you'll get the oil temp issue solved...................Doug
pullmytrigger is offline
Old 06-24-2002 | 11:43 PM
Audiofn's Avatar
Charter Member #232
How do you test/fix that? I was having a similiar problem with my engine??? Well let us know the end is certainly in site!!!!
Jon
Put your best foot forward!
Audiofn is offline
Old 06-25-2002 | 01:03 AM
gofastboater
Foul, thanks for the call on Saturday. I was on my way down to the marina and got side tracked along the way...I know excuses...excuses....I tried to look up on Sunday!! I must have missed ya....was looking forward to seeing the Waterfoul running.
Give me a call soon, I'll have to take you a spin on my new ride!!!
GFB
Old 06-25-2002 | 01:15 AM
Mike, glad to here everything is getting on the right track. I'm sure you'll get the oil temp figured out and have a 100 hrs on the boat by the end of the season.
Griff is offline
Old 06-25-2002 | 10:01 AM
traviss's Avatar
Sounds like everything is going good mike.. That bypass in the adapter is what i just fixed on the powerplay.. It was going through the bypass instead of the filter, cooler, oil stat. Talked to a few people and then called tyler crockett, he said to remove the valve and tap the hole to put a pipe plug in it. Instead I just welded up the bypass hole, then you have to run a high burst oil filter, in which I am running the Fram HP4 (small block chevy) The thing that told us that it was going through the bypass was it had more oil pressure at idle then it did at cruise and WOT and the oil was hot.. After fixing the problem my oil pressure is great but my oil is still 230 at cruise.... 270 at WOT .. I have to buy a bigger oil cooler when I get the cash.
don't worry man.. i have a been FOULized again this weekend.. this weeks parts for the boat, new coil, carb fuel filters, PCV system... plus i have oil all over the bilge and no traces of where its coming from LOL! but its all worth it after I spanked that guy in his BBC jet boat
Yeah and where has Crazyhorse been???..
Any questions mike let me know..
[email protected]
Good luck
Travis
traviss is offline
Old 06-25-2002 | 10:29 AM
dyno's Avatar
Charter Member #655
Hey Travis!!!! Dave is still off from work.....vacation this time 3 weeks off.... what a scab! called him on his cell last night to talk but I think he's on vacation time if you know what I mean....Did you see my Milk post? any thoughts?
Dyno
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 06-25-2002 | 04:52 PM
traviss's Avatar
hmm dyno... your milk problem ... don't really know it could be anything i guess... hell my motor has clean oil, but in my valve covers I have white sludge and water LOL! any my oil is getting way hotter so it does boil the condensation out.. its a wild goose chase... my could be reversion too.... hell i don't really worry as long as the oil is nice its stays in the boat!
chat with ya later about this gotta run don..
Travis
traviss is offline
Old 06-25-2002 | 06:22 PM
DanB's Avatar
Charter Member #71
Mike
Glad to hear your back in business...now go out and run the snot out of it and enjoy!!! Keep in touch.
Dan
DanB is offline
Hot4Teacher
1
08-11-2006 11:22 PM
Wild
04-22-2005 08:39 AM
ArtsWarlock
American Offshore
1
10-28-2002 07:47 PM
Waterfoul
06-22-2002 10:30 PM
