Shorty on 89' Bravo?
You will have to compare the water passage on your old lower, there is probably not an island with an oil passage drilled in it. The Imco probably will. The lower would need to be tapped and a plug inserted to seal it off. Then it will work like the old lower.
You also need to shorten the bolts holding the cavitation plate on the upper.. they will hit the new lower..
Hope that helps.
Dick
Hope that helps.
Dick
