GMC or Chevy gear ratio
Old 03-23-2012 | 04:12 PM
masi242's Avatar
Default GMC or Chevy gear ratio
I`m looking at getting a new truck to me 2oo7-2oo8 1500. The gear ratio has me a little confused I would like to find a z-71 with 3.73 gears but would a 3.43 be ok. I`ll be towing around 5500-6000lbs only one long trip a year. The boat is docked so in and out only a few times to clean. I would have the 5.3 with factory hitch.
Any thoughts good or bad it will be nice to get rid of the Dodge.
masi242 is offline
Old 03-23-2012 | 04:56 PM
Default fixx
try to find a 3.73,,better for pulling..
FIXX is offline
Old 03-23-2012 | 06:12 PM
masi242's Avatar
Thanks that`s what I`m shooting for.
masi242 is offline
Old 03-23-2012 | 06:55 PM
Default fixx
also the z71 has a bigger diff..dont over look the 1500 hd also,has 8 lug wheels and 10 ply tires which will be more stable for pulling..
FIXX is offline
Old 03-23-2012 | 07:21 PM
aquaforce's Avatar
A guy I work with pulls that same weight with 05 5.3L and 3:42. The truck does it but he has burned out 3 rear ends. The higher ratio is strongly advised.
aquaforce is offline
Old 03-23-2012 | 07:58 PM
obnoxus's Avatar
Charter Member #1171
3:73,,,,,,or 4:10 if you can find one,,,, not sure if they did that in a 1500
and on that note,,,,,look for a 2500 to,,,,,alot more truck for the same $$$$ better trans, bigger brakes etc
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 03-23-2012 | 08:22 PM
aquaforce's Avatar
Yea, a 2500 is also emission exempt, if you have to deal with that there.
Old 03-23-2012 | 08:43 PM
jusy have the rear end regeared, about 1k
JJONES is offline
Old 03-23-2012 | 08:47 PM
And front
prostock85 is offline
Old 03-24-2012 | 04:25 PM
masi242's Avatar
I have driven the 2500hd the one I looked at was ok more used than I wanted. My Dodge has the 360 in it and 3.55 gears if I remember right and does ok and I added a trans cooler and oil cooler pretty easy. It`s my daily driver thats why I was going 1500 route, I tow less than 100 miles a year unless we do a week away.
I won`t miss the Dodge
masi242 is offline
